Re: Mag to Distributer
Posted by Bob M on August 05, 2004 at 06:27:48 from (165.170.128.66):
In Reply to: Mag to Distributer posted by Ted on August 05, 2004 at 06:07:12:
Ted – The “conversion” uses the existing magneto points/condensor to control battery power to fire a standard externally-mounted ignition coil.
To make the conversion run power from the ignition switch to one of the external coil primaries. Then connect the other coil primary to the points terminal inside the mag. The old mag coil primary must be disconnected from the points (or the mag coil can be removed entirely).
Hope this helps!
Post a Followup
Subject:
