Farmall Tractors Discussion Board
Re: A oil
Posted by Farmer Bob on November 05, 1999 at 19:14:26 from (207.227.187.61):
In Reply to: A oil posted by Chuck on November 05, 1999 at 15:37:10:
Forgot to mention the weight of oil..This depends on where you're at and what you use the tractor for. Normal use in normal temp climate I'd go with straight 30W. If you will be using it in cold weather you could use a multi-grade such as 10w-30 or straight 20w. Remember, if the oil won't drip out of the check ports (and you know that there's plenty of oil in it), don't start the engine! You will do damage to a whole array of things and mainly bearings. FB
Post a Followup
: Re: Re: A oil
