Re: M hood belt pulley questions
Posted by Roger WI on August 05, 2004 at 20:08:39 from (69.58.151.157):
In Reply to: M hood belt pulley questions posted by RossMN on August 03, 2004 at 21:00:45:
Ross, I have seen this with hoods before. When people take off the hood it doesn't come off easy unless you spread it apart. My dad used to get mad at the hood and bend it out so it came off easier. Then the latches can't hold it because there is so much pressure pushing out on the hood. I have corrected this by taking off the hood, setting it on the ground, and making sure the sides are vertical and not bowed out at the bottom. If they are, bend each side so the sides are vertical. Roger
Post a Followup
Subject:
