Re: Farmall H Antifreeze
Posted by captaink on August 06, 2004 at 10:54:27 from (66.115.212.249):
In Reply to: Farmall H Antifreeze posted by bil on August 06, 2004 at 08:26:59:
#1 There are many possibilities but my guess since you say there was no antifreeze in the cylinders is that there is a crack somewhere on the bottom of the block or behind one of the sleeves themselves. Pull the pan and look for antifreeze hanging on the inside of the block. If you don’t find anything, then take the head off and have it checked by a reputable machine shop. The leak is definately inside your engine somewhere.
#2 The lockup was very likely caused by the antifreeze. Antifreeze is sticky, and will seep into bearings and other metal mating surfaces. I would suggest you disassemble the engine, have it cooked out at a machine shop to eliminate any possibility of antifreeze in oil galleys, determine where the leak was, and then reassemble with new bearings on the crankshaft and camshaft. Since you will have it apart, I would consider a valve grind and new rings at least if not a major overhaul.
Good luck!
Post a Followup
Subject:
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
