Re: frozen gears
Posted by lee on August 07, 2004 at 10:15:57 from (24.24.95.246):
In Reply to: Re: frozen gears posted by Jim Becker on August 07, 2004 at 07:33:18:
I did this exact fix on a MF135 last week. Guy had the tractor in first gear. He was off the seat working at the side of the tractor. He wanted to put it in neutral for some reason.
He deppressed the clutch with one hand and shifted it to neutral with the other. The shifter came to neutral but the tractor was still in first. He had apparently pulled the shifter off to the side as well as toward neutral when he shifted it. If your tractor is prone to this problem, shift it straight in and out of gears.
Side loading the shifter will aggravete the problem.
Post a Followup
Subject:
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
