Re: What went wrong???
Posted by Gene on August 07, 2004 at 23:54:15 from (208.144.172.163):
In Reply to: What went wrong??? posted by Dewa on August 07, 2004 at 22:35:36:
Guess, starter is stuck in the flywheel. Pull the starter and see if the engine is free. If the distributor is sitting done tight, fully seated on the base - that's not the problem.
If the engine is free when you pull the starter, fully charge the battery - like over night, then try it again. A weak battery will have just enough juice to turn the starter and drive the over running clutch and gear into the flywheel sometimes locking them together. You could also try a known good battery.
If it's not the starter, disassemble the engine in reverse order of assembly until you find the problem.
Post a Followup
Subject:
