Re: frozen gears
Posted by Diana on August 08, 2004 at 06:13:39 from (205.188.117.22):
In Reply to: Re: frozen gears posted by Hugh MacKay on August 08, 2004 at 03:51:56:
Hi Hugh,
You're right. I couldn't find a new one. Tom is extremely busy at work right now, so I will have to wait a little bit to have it done.
As far as two gears at the same time, Tom sorta figured this is what had happened, so it does need some work soon.
I really think the clutch isn't quite right, too. Sometimes when I push the pedal all the way down, I can hear a whishing sound. I just know it isn't a noise that is supposed to be there.
When I had sent the tractor in for it's mechanical makeover, the guy said he adjusted the clutch "a little bit", even though I told him not to touch it. I'll have to re-check the adjustment on that and hope that it's the reason for the sound.
Thanks for the advice. I sure appreciate it!
Diana
Post a Followup
Subject:
