Re: Weighty Matters
Posted by lee on August 08, 2004 at 06:52:57 from (24.24.95.246):
In Reply to: Weighty Matters posted by Dakota Jim on August 07, 2004 at 21:19:40:
10W-30 acts like a 10 weight cold and a 30 weight hot. please explain your problem a bit more. Does the oil presure drop off while running hard? You say the oil pressure improves when you back off throttle and wait a few minutes? How long. Do you have a temp gage on it? Is the engine getting hot and then cooling down significantly? Does your oil gage have any numbers you can post? Other than overheating or worn engine bearings or worn pump an old overhead valve engine can sometimes trap oil in the valve cover causing low oil pressure due to low oil level in the pan after hard running. The drain back holes in the head can sometimes get clogged if the motor is sludged up inside.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
