Re: frozen gears
Posted by Jim Becker on August 08, 2004 at 08:01:41 from (4.29.47.118):
In Reply to: Re: frozen gears posted by Diana on August 07, 2004 at 18:58:12:
Building up the tip of the shift lever will help the "knuckle busting" problem as well. Wear at the bottom end is multiplied into extra motion required at the top end.
Post a Followup
Subject:
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
