Re: 460 clutch???
Posted by Lloyd on August 08, 2004 at 10:29:08 from (199.120.84.149):
In Reply to: 460 clutch??? posted by hagan on August 08, 2004 at 09:46:52:
There is a small splined coupler, I believe it is past the clutch but before the TA that could be worn out. It happened to me on my 460 once. You need to split the tractor at the engine clutch to reach it. Can you see any shafts turning with the inspection plate off in the TA unit?
Good luck
Post a Followup
Subject:
