Re: IH 384 - Does the injectors need to be reprime
Posted by Mac on August 08, 2004 at 17:14:43 from (217.144.243.200):
In Reply to: IH 384 - Does the injectors need to be reprimed? posted by BradleyB on August 08, 2004 at 14:24:25:
There should be two filters with bleed screw on top, one on each side of engine. From the seat, the one on the right is primary and should be bled first, then the other. Then crack supply line at pump until fuel escapes to avoid running pump dry. I don"t usually bother with inj lines as it just makes a mess. (Once pump is primed, fuel is going somewhere) I"ve seen a lot of guys just crack inj lines and crank, crank and crank and freeze pump.
Post a Followup
Subject:
