Re: fuel strainer removal, super C
Posted by ken2 on August 09, 2004 at 13:39:25 from (66.84.80.95):
In Reply to: Re: fuel strainer removal, super C posted by Brian Schmidt on August 09, 2004 at 13:26:07:
Thanks guys. I just came up from taking it off. Yup, 3/8 inch thread. The plug from an old hurricane lamp fits nicely. I gave it a shot of WD-40 first, let it sit a half hour then gave it a twist and out it came like it had never been stuck. I filled it with a quart of lining fluid, sloshed it around, poured off the excess (not much) and am letting it dry overnight. I also cleaned and touched up the tank's exterior paint.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
