farmall h carb
Posted by jason on August 09, 2004 at 17:44:42 from (209.143.56.56):
the rpms on my farmall h run nearly wide open when the throttle lever is barely moved the butterfly in the carb is nearly closed and it still seems to run wide open with no speed control
Post a Followup
Subject:
