Re: Farmall H Engine Oil Pressure
Posted by captaink on August 11, 2004 at 13:50:52 from (66.115.212.249):
In Reply to: Farmall H Engine Oil Pressure posted by Eric on August 11, 2004 at 11:39:49:
My 2 cents. A lot of discussion on this lately, and most of it basically says “as long as you have some oil pressure, don’t worry until it’s time for a rebuild.” I disagree. I have a “B” an “M” and a 51 GMC truck that all at one time had low oil pressure at warm idle. I did not think it serious as they still had some pressure so kept running them. In EVERY ONE there was a problem. The “B” had a warped plate and blown gasket on the oil pump, the “M” had crankshaft bearings “flaking” (I found a few when I changed oil) and the GMC had anti-freeze leaking into the crankcase. When these engines finally came down, the “B” needed the crank ground “0.020”, the “M” “0.030” and the GMC crank was shot (the M and the GMC both eventually spun a rod bearing). My opinion is that unless you have a “dipper” oiling system, if you have idle oil pressure at less than ¼ of the gauge or 15#, the engine has a problem. I would drain the oil and check for flakes in or around the drain plug. If you find some you know what is going on. If not, consider taking the pan down and plasti-gauging the bearings. At least then you will know if the bearings are just worn a bit or if you have real trouble brewing in the engine. I just tore apart a 351 V-6 that had a light “knock” at high idle, but “reasonable” oil pressure. The number 6 rod bearing and back main are almost “hammered” out totally, and the rest have light scratches. Thanks to the quick tear down we will be able to salvage the crank and rods. (The engine had 250,000 miles on it.)
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
