Re: international 354 gas engine block
Posted by lee on August 11, 2004 at 16:50:16 from (24.24.95.246):
In Reply to: Re: international 354 gas engine block posted by Vic Barber on August 11, 2004 at 16:35:23:
yes, but this is a wet sleeve engine. The cylinder bores are sleeves that press in place with o-ring seals at the bottom of the sleeves to keep the oil and coolant in their separate compartments. Leaks often develop at the o-ring seal. Can you see a crack in the block? Make sure it's not just the o-ring seals. Now you'll probably have to have it re-built with new sleeves but maybe you don't need a block.
Post a Followup
Subject:
