Its charging finaly
Posted by chad from michigan on April 02, 2009 at 17:15:11 from (67.142.164.30):
Well thanks to all that helped. after many go arounds of me getting up set and few of you getting upset the actual problem was the VR needed adjustment. the spring needed more tension. I moved it very little and started the tractor and it had 15 amps. I adjusted it back to 8 amps on full trotal and 0-2 amps at idle.
I am going back to make sure I have it adjusted correct with the lights running I have to re-read my posts from you guys.
thanks
