Re: Super C brakes
Posted by BIG JOHN on August 12, 2004 at 18:56:32 from (64.12.116.14):
In Reply to: Super C brakes posted by Wayland on August 12, 2004 at 15:06:26:
Remove the outer cover which is also the outer plate and you will find the first brake disc, then the actuater, and then the second brake disc. The last thing is the inter plate which has the shaft seal. The brake system should be dry unless the seal is leaking. The inter plate is a press fit with an O-ring into the transmission. You will find notches to use a wedge tool to separate it from the transmission. If the seal is not leaking you will not need to remove the inter plate.
GOOD LUCK
Post a Followup
Subject:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
