Re: Farmall H questions with a belly mower.
Posted by Michael Soldan on August 13, 2004 at 05:09:04 from (216.46.130.24):
In Reply to: Farmall H questions with a belly mower. posted by DT on August 12, 2004 at 20:51:33:
D.T..your oil can be 15w40 for that old tractor engine especially if it burns a little oil. Rear oil can be a 90 gear oil or the 80/90 version. I find Walmart usually has the best price on rear end oil around $29 for 5 gallons as opposed to $80 at the tractor dealers. I am not sure why you want to power your mower from the pulley belt although it can be done. Most belly mowers are designed to drive off the PTO and will come with the hook up to do this. Usually there is a gear box that bolts onto the drawbar or rear of the tractor, runs off of the PTO and v-belts to the mower deck. Good luck with your project....Mike in Exeter Ontario
Post a Followup
Subject:
