Re: W4 crankcase has something in it??
Posted by captaink on August 13, 2004 at 07:28:04 from (66.115.212.249):
In Reply to: W4 crankcase has something in it?? posted by Jeff Elder on August 13, 2004 at 06:55:59:
You should never, I repeat NEVER find anything in your oil pan except dirty oil. Pop that pan off and find out what is going on. It is possible that someone put shim stock behind one of the crankshaft bearings rather than get the correct bearing or grind the crankshaft to get the correct clearance and this may have worked out somehow. It could also be a plate or part of washer that is used to lock the main and/or connecting rod bolts to keep them from getting loose.
At any rate pull the pan and find out what is going on. My 2 cents…
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
