Re: Farmall H questions with a belly mower.
Posted by rustyfarmall on August 13, 2004 at 08:23:15 from (199.120.81.199):
In Reply to: Farmall H questions with a belly mower. posted by DT on August 12, 2004 at 20:51:33:
I suppose if you are enough of an engineer and a fabricator then you could do it. The old #24 fully mounted corn picker was powered by a drive chain. The drive sprocket was powered from the belt pulley, the sprocket was bolted on in place of the actual pulley. Your idea is feasible but will take a lot of work to make it practical.
Post a Followup
Subject:
