Re: M Clutch won't disengage!! HELP!!!
Posted by rustyfarmall on August 13, 2004 at 12:25:39 from (199.120.81.204):
In Reply to: M Clutch won't disengage!! HELP!!! posted by Jason(PA) on August 13, 2004 at 12:00:14:
Apparently the clutch was working OK before?
If so then you are doing the correct thing, might just take a little more of it. You might try parking the tractor in an open area, put it in 5th gear, set the brakes, hold the clutch down, and then try starting it.
Post a Followup
Subject:
