IH 340 util Rear Rims
Posted by Doug V on August 14, 2004 at 17:02:50 from (68.237.143.73):
Well I got that bead broken on some old dry rotted tires. I then found the rims have some rust holes. Is it worth welding or should I just find some used rims and if so where should I begin to look?
Doug
Post a Followup
Subject:
