H4 Magneto refurbish Service
Posted by Eric on August 15, 2004 at 13:03:28 from (195.93.34.14):
Decided to service 1945 Farmall H magneto today condeser points Etc.. one question I have (well maybe problem) i decided to dismantle the distributor body to see if everthing was OK now I realise there must be a need to time the spindle/rotor drive, with the pinion I see that the pinion has a notch out of a tooth and the spindle/rotor drive has what looks like a timing mark with a left and right mark with one tooth variable are these the timing marks? any help appreciated. my repair manual IH8 does not give much detail about the magneto. Thanks in advance Eric
Post a Followup
Subject:
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
