Re: bad water pump???
Posted by captaink on August 17, 2004 at 07:21:39 from (66.115.212.249):
In Reply to: Re: bad water pump??? posted by Allan in NE on August 17, 2004 at 05:05:31:
What you are seeing is normal.
One other thing besides leaking to check on a water pump is to loosen the belt that drives it and check for wobbling of the shaft. If it wobbles much at all, replace it the bearings are going bad. Water pumps can also sometimes make slight grating noises just before they fail.
Post a Followup
Subject:
