Re: carb switch to help gas hog 300 utility
Posted by Unreserved dick on August 17, 2004 at 08:21:42 from (4.228.129.45):
In Reply to: carb switch to help gas hog 300 utility posted by K B in Pa. on August 16, 2004 at 22:28:13:
As the other guys said, the 300U and 350U carbs are the same. Have you tried adjusting the one you've got? My experience is that these tractors aren't so bad on fuel if you run with the main jet screw only a turn or so out except when you're doing heavy work and need the extra power.
Post a Followup
Subject:
