Re: carb switch to help gas hog 300 utility
Posted by Ken in Iowa on August 17, 2004 at 20:28:17 from (12.64.6.158):
In Reply to: carb switch to help gas hog 300 utility posted by K B in Pa. on August 16, 2004 at 22:28:13:
On light loads try a higher gear and run the engine a little slower. As I recall the utility engines ran at higher RPMs than the Farmall. When you expect full power be ready to put in the fuel. I put a 13 gallon auxilary tank on mine mounted on the front and have used it that way for almost 30 years. The normal tank only holds about 10 gallons.
Post a Followup
Subject:
