Re: ih 574
Posted by TBW on August 18, 2004 at 18:33:28 from (63.191.136.14):
In Reply to: ih 574 posted by kj(il) on August 18, 2004 at 17:52:24:
Try pulling the gas bowl out of the tank. Ours was pluged up when we got it. the stem sticks up in the tank a little and you can"t tell unless you pull it out. I had my son stick his finger in the hole while I cleaned the bowl and stem.
Post a Followup
Subject:
