Re: Do I need dual remotes on a 706 to use a loade
Posted by Nebraska Cowman on August 19, 2004 at 05:32:19 from (65.162.146.189):
In Reply to: Do I need dual remotes on a 706 to use a loader posted by Brett Munsey on August 19, 2004 at 03:58:23:
I added a second remote to my 656 from the salvage yard.
Just make sure you get the right one. What you need is the second valve, you remove yours (which is the outside or 1st valve) and sandwich the second one.
Post a Followup
Subject:
