brake settings on F-30
Posted by Farmall on August 19, 2004 at 19:03:01 from (209.240.205.63):
Can anyone tell me how tight the brake drum should be against the brake pads on a 30? Ive got it now with just the big, beveled for the screws shims on. I can put the drum on, but I cant turn it by hand. The thinner shims benieth the thick shims arent beveled for the screws to hold them and the heads stick out. I imagine I could get a bit better fir by using these thinner shims, but I wanted to ask you about if there would be a problem with the screw heads sticking out from the screws against the brake shaft. Thanks. For some reason Im not getting E mailed when I send in posts, so if you would, would you E mail me with your answer. Im at farming20@webtv.net Thanks
Post a Followup
Subject:
