Re: Tricky Timing Question
Posted by El Toro on August 21, 2004 at 19:42:42 from (66.119.33.135):
In Reply to: Tricky Timing Question posted by Josh on August 20, 2004 at 18:40:51:
Hi Again Josh, Rotate engine until No1 cyl is at TDC then install cam gear as you did the first time and see if it is still off one tooth when
you rotate the engine 180 degrees. With the crankshaft keyway at 12 o'clock the dot on this
gear should be directly above the keyway. I wouldn't know why they would have so many punch marks on the cam gear since you only have 3 gears to align unless it is used on other tractors. Hope this helps, Hal
Post a Followup
Subject:
