Re: Farmall W14 parts
Posted by Peter Phillips on March 10, 2009 at 13:39:19 from (123.211.163.244):
In Reply to: Re: Farmall W14 parts posted by oldiron29 on March 09, 2009 at 16:57:32:
Hi oldiron29. Yes, the shutters on an F12 or F14 are the same as a W14 but the radiator cap on the F12 or F14 just have a wing nut to secure it to the radiator tank whereas the W14 has a larger scalloped edge part with a cantral bolt on top of the sealer plate. All of the F series I have seen have had the radiator cap the same as the engine covers on a 10-20. Any ideas where I can find either of these> Thanks for your reply.
Peter.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
