Farmall Tractors Discussion Board
Re: 1952 Farmall H oil cover
Posted by john on November 08, 1999 at 13:46:44 from (198.70.112.100):
In Reply to: 1952 Farmall H oil cover posted by Tom Bowes on November 06, 1999 at 18:46:03:
Tom,
Are you talking about the canister cover over the oil filter?? If so how could you have driven the tractor with this off? (doesn't the oil fly all over everywhere?) If this is it I have one for the larger oil filter (heavy duty service) that I could get for you real cheap.
Post a Followup
: Re: Re: 1952 Farmall H oil cover
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
