Re: 300 deal?
Posted by Bill in Orono,MN on August 24, 2004 at 16:16:06 from (66.82.9.38):
In Reply to: 300 deal? posted by BrokenFences on August 23, 2004 at 18:45:02:
A deal perhaps, but I have a overhauled, gone thru, etc. 300 that
runs like a champ, TA is perfect, wide front, independent PTO,
Twin cylinder 3pt. hitch, and 3 remotes (one in use for the 3pt.)
One new rear tire, rest hold air and are varying degrees of
weathered.
New Chrome cover on coil. Makes it look fast. Or at least like it
has a chrome cover on the coil.
Will pull my 3-14 IH Mdl 70 plow through clayey soil. ('course it
helps that I have 900lbs of weight on the rear axle.)
Sand blasted metal, Two year old paint. Every thing on it works.
Much new.
$4000. Yep. $4000.
FYI did you know the Case-IH distrubutor cam for these goes for
$382.00?? WOW!
Post a Followup
Subject:
