Re: IH 574 Diesel
Posted by captaink on August 25, 2004 at 11:14:42 from (66.115.212.249):
In Reply to: IH 574 Diesel posted by TDK on August 25, 2004 at 10:58:48:
Did you just buy the tractor? If not have you done anything to it lately?
If you just bought it, check the timing and mark where it currently is for a reference. Try retarding it just a bit and see if that helps. If it makes it worse or has no change, try advancing it. If again no change or makes it worse, set it back the way it was.
It could be injectors or even the pump causing this. Could be some other things, but I’d try these first and see if it helps.
Post a Followup
Subject:
