Farmall Tractors Discussion Board
Re: 12v Farmall Conv..more help please
Posted by CHUCK ANEMA on November 08, 1999 at 18:57:23 from (207.65.141.96):
In Reply to: 12v Farmall Conv..more help please posted by Gee on November 08, 1999 at 15:38:41:
POWER IS EQUAL TO I SQUARED TIMES THE RESISTANCE VALUE. IF YOU ARE CHARGING 3 AMPS THROUGH A 10 OHM RESISTOR THE POWER WOULD BE 90 WATTS. 3X3 X R. THIS IS JUST AN EXAMPLE. IF YOU KNOW THE CURRENT AND THE RESISTANCE VALUE CALCULATE THE POWER AND USE A RESISTOR WITH AT LEAST TWICE THE POWER CALCULATED. A 1/2 WATT RESISTOR SOUNDS PRETTY SMALL AROUND A CHARGING CIRCUIT.
Post a Followup
: Re: Re: 12v Farmall Conv..more help please
