Re: #60 grader blade
Posted by Erik Dekeyser on April 02, 2009 at 18:26:53 from (207.200.132.96):
In Reply to: #60 grader blade posted by Cue P. on April 02, 2009 at 14:23:14:
Yes you might damage the grill on your super A if there is any wear on the lift linkage it will hit the right hand side of the tractor. You can fix that with a little work and a few washers i think, or you might have to bend it with a little heat. The front blade is also hard on the steering on the A. But they do a good job of leveling and moving snow if its not to deep.
