Re: Sprinkler system
Posted by MD Wa. on August 26, 2004 at 06:08:37 from (4.178.111.46):
In Reply to: Sprinkler system posted by JD in CAN on August 25, 2004 at 21:08:52:
JD. You might want to work backwards. How much water (gpm) will you need. Size of tank. Number of sprinkler heads. Size of pipe. Then check with any tractors store or ind. suppy for a PTO pump that will work with on the HP you have (19.06). You might have to go a hyd. pump and motor to get the gpm that you need or want. Hpoe this gives you a starting point. Morgan
Post a Followup
Subject:
