Re: hesatition question
Posted by captaink on August 26, 2004 at 06:39:37 from (66.115.212.249):
In Reply to: hesatition question posted by bob s on August 25, 2004 at 15:09:06:
When it starts hesitating, check the spark. It should be bright blue all the way to the spark plugs. If not then you are on the track with points, condenser, coil, etc. If you still have a bright blue spark you need to look somewhere else like valve adjustment or a plugged gas cap.
Post a Followup
Subject:
