Re: Farmall H engine I.D.
Posted by DWV on August 26, 2004 at 20:18:13 from (64.12.117.22):
In Reply to: Farmall H engine I.D. posted by Red Dread on August 26, 2004 at 16:16:11:
Unless you'r engine has been upgraded.you have a
small journal crank,low compression head with 3/8
studs for bolting manifold to head instead of 7/16. begining at 391358 engine # crank was changed to larger journal.Same as SH.Order pistons for compression that will work best for intended use of tractor. As others say measure
before ordering.
Post a Followup
Subject:
