Re: Timing questions
Posted by MagMan on August 27, 2004 at 05:52:20 from (64.12.117.22):
In Reply to: Re: Timing questions posted by ffolkes on August 27, 2004 at 05:40:43:
#1 Piston at front of motor Take a small piece of wire long but small diameter and find when the #1 piston is at the top of the compression stroke Hand crank with finger in hole to see when its coming up on compression then use the wire when its at the derect top look at your timing marks and see if they are in line with the pointer or not.Then check and see where your rotor is pointing should be at # 1 on cap also. JON
Post a Followup
Subject:
