Re: Broken Throttle Block on 300 Utility Carb
Posted by JTF439 on August 27, 2004 at 09:42:03 from (63.155.196.246):
In Reply to: Re: Broken Throttle Block on 300 Utility Carb posted by TractorTom on August 26, 2004 at 10:33:33:
It is the notched piece pressed onto the throttle shaft that the little governor pin goes into.It is part of the carb.I took the two throttle plate butterfly screws down in the carb off and the throttle pin with this piece I need pulled right out.
Let me know and thanks
Post a Followup
Subject:
