Re: Right about that, but still no go
Posted by MagMan on August 27, 2004 at 09:49:50 from (64.12.117.22):
In Reply to: Right about that, but still no go posted by ffolkes on August 27, 2004 at 08:04:12:
DEAR FFOLKS I have been rebuilding H4 magnetos since I was 15 years old. I gave you my phone # and everything. I take it you sprayed the impulse with your cleaner. Under neath that there is a spring that has like a cardboard seal in it to soak up oil and there is alot of room in the housing. Thats probly where your spray went. If you take the 4 screws out of the coil cap and look under the coil you will see the magnet if its clean in there when you tip it its ok look for moisture under that cap. If you have spark at the plugs and its in time and the valves are opening it must be a fuel problem, Stop using the either.Put 3 or 4 small caps of gas in the carb opening and hold your hand over the carb and turn it over and see what happens. If it pops or back fires you have it 180 off. Let us know. and here is a link for a rebuilt mag if you want I also give money for exchange. JON
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3835741643
Post a Followup
Subject:
