Re: Compression in H with domed pistons
Posted by riverbend on August 27, 2004 at 19:18:22 from (208.160.33.253):
In Reply to: Compression in H with domed pistons posted by Red Dread on August 27, 2004 at 16:33:23:
Check the compression with a little oil in the cylinders. If it does not come up any, the rings could be good. On the other hand, if you have it all apart, why not put a set of rings in it?
When I put the domed pistons in my H I measured all the pieces and calculated a C.R. of about 6.5:1, so about 100 psi sounds right to me, but I have not actually checked.
It runs a lot better than it used to.
Post a Followup
Subject:
