Posted by Dr. Bert on April 02, 2009 at 18:46:58 from (72.36.57.58):
In Reply to: Hard steering Super M posted by oliver77 on April 02, 2009 at 15:27:54:
oliver77: Do as suggested- jack up the front end so both wheels are off the ground. If this doesn't ease the steering loosen the studs on top of the spindles. (holds the steering arm? on.) Do one side at a time. On my M I found that the square stock key was too long and when the above mentioned stud was tightened, it forced the key down the keyway and caused it to bind against the side of the tube. My memory is a little hazy about specifics, but anyway you may find the problem in that area. Good luck Bert
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
