Re: Rod bearings on my 300
Posted by scotty on August 28, 2004 at 07:28:04 from (199.231.49.128):
In Reply to: Re: Rod bearings on my 300 posted by Kelly C on August 28, 2004 at 07:13:33:
Kelly,
Easiest way to see what you have is to mike up your journals. They should all be the same unless someone at one time repaired just one.As the post below stated, a good check is to use plastigage to check your clearances.
As far as the polishing, you might be able to use some really fine Scotch-Brite, but I would be careful with even that.
scotty
Post a Followup
Subject:
