Re: Rod bearings on my 300
Posted by RussR on August 28, 2004 at 09:12:28 from (24.128.229.219):
In Reply to: Re: Rod bearings on my 300 posted by Gene on August 28, 2004 at 07:35:45:
Gene's rite: Use the plasigage technique and get hold of an engine repair manual so you can review that section and do your best work. Put the emery on the side of your work area with a large poster that says NEVER USE THIS ON MAIN BEARING
COMPONENTS. With emery cloth you will start from SCRATCH and toss the block in the PATCH. Good luck in your precision rebuild.
Post a Followup
Subject:
