Re: 560 gas mileage?
Posted by Tramway Guy on August 28, 2004 at 20:04:57 from (24.58.204.40):
In Reply to: 560 gas mileage? posted by Chris Brown on August 28, 2004 at 18:45:27:
Gas engines don"t get much better "mileage" when operating under light loads than they do under full load - - unlike a Diesel engine. I think 4 gal/hr is probably about right if 5.5 gph is full load usage.
IHC built a 301 CID engine without sleeves for industrial/vehicle applications. That may be what you have. The bore would be larger than a 560"s.
Post a Followup
Subject:
