Farmall Tractors Discussion Board
Re: Re: Re: Odd request for a Farmall Model M 1951
Posted by RED Blooded on November 09, 1999 at 13:00:01 from (206.74.34.75):
In Reply to: Re: Re: Odd request for a Farmall Model M 1951 posted by John on November 09, 1999 at 12:01:29:
To get the colomn off you need to remove the hood and disconnect it from the other shaft.Up under the throttle there should be 2 collars with set screws in them.Remove the wheel and the collar closest to it and it should slide out toward the front of the tractor.
Post a Followup
: Re: Re: Re: Re: Odd request for a Farmall Model M 1951
