Re: Industrial tractor?
Posted by Hugh MacKay on August 29, 2004 at 21:44:42 from (216.208.58.112):
In Reply to: Re: Industrial tractor? posted by chuck pratt on August 29, 2004 at 18:16:03:
Chuck: The main reason I questioned the model number was never having heard of a 2405, nor could I find it in any reference material I had. You just raised a good point, that being a possible 2400 or 240. What does the tractor have for an engine? Should be C-123, C-135 0r C-153 cast into block. Engine serial will be stamped on a machined flat surface under number 1 plug.
We need to get this model number right before tractor serial number will help much.
The ballasted coil is one not needing a ballast resistor, it being built right into coil. I have those on two of my tractors.
Post a Followup
Subject:
