Re: Ideas On H stuck piston removal
Posted by captaink on August 30, 2004 at 10:52:57 from (66.115.212.249):
In Reply to: Ideas On H stuck piston removal posted by MagMan on August 30, 2004 at 10:14:15:
I heard a new one this weekend but have not had a chance to try it. One guy told me he makes a plate out of ¾” thick material and taps a hole in it to put on a fitting to connect his port-a-power. Then he bolts this piece to the top of the block over the piston that is stuck. He connects his port-a-power and starts to carefully pump fluid into the cylinder. He said this has never failed him yet.
Good luck and please post back your results if you try this.
Post a Followup
Subject:
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
